04-23-2022
01:42 AM
04-23-2022
05:54 PM
computergeek541
i have the $15 plan. i tried to text to a Vietnam number. the status shows it is sent and received. but the recipient do not get the message.
is international texting means all countries or just some selected?
04-23-2022 05:48 PM
04-23-2022 09:20 AM
Make certain you're sending the message as an SMS and not as an iMessage or Chat message.
Sometimes using iMessage (Apple) or Chat (Android) can cause delivery or receipt issues of messages even through they are sent via the device's Messaging app.
You might also want to try to ask a friend or family member (in Canada) to try to send this recipient a text message to see if they get those.
04-23-2022 02:34 AM
You can send and receive international SMS/MMS texts. But does your recipient have international incoming SMS? MMS? Or both SMS/MMS texts included in their plan? That may be the issue. If they don't you might both need to use Whatsapp or Messenger. Or have them download textnow and pick a canadian number and you can text and call for free on WiFi or use mobile data.
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #
04-23-2022 01:48 AM
Firstly, enter Canada exit code 011. Secondly, type Vietnam country code which is 84. Finally, dial local number and you will reach to the correct destination. There are more than 60 area codes in Vietnam. Example – 011 84 4 xxxx xxxx
04-23-2022 01:46 AM
Yes you can text to international numbers
