add-on data isn't working?
04-18-2018 05:21 PM - edited 01-05-2022 04:38 AM
Hi there,
I ran out of data so I decided to buy a 200mb add on. I've paid for it - how come I still can't use my data?
Thanks
Payment
04-19-2018 01:56 PM
Here's a tutorial for anyone unfamiliar with the add-on purchasing process:
04-18-2018 05:36 PM - edited 04-18-2018 05:36 PM
@jp2 wrote:So you charge your credit card the add on amount once and then charge your account the add on amount to activate the add on once. Right?
Correct, it's a two-step process.
04-18-2018 05:30 PM
04-18-2018 05:26 PM - edited 04-18-2018 05:27 PM
@jblackwell wrote:Hi there,
Thanks
The add-on process is a bit cumbersome - you basically buy it twice.
Go into Self-Serve and see if the add-on is actually there for you - if it's not, check to see if your available funds is showing the add-on amount. If so, you have to "buy" it again but this time it'll be purchased with those available funds.
Why I said "twice" is because the first time you only get the funds added to your account but it doesn't actually enable the add-on. This is why you have to do it twice.
Hope that all made sense. 🙂
If the add-on IS showing for your account then you'll need to contact a moderator to see what's going on.
