05-29-2024 10:22 AM
Since Monday ALL posts Yummy makes end up in
https://productioncommunity.publicmobile.ca/t5/premod/moderationitemspage/tab/rejected
Even simplest post like 'test' ended up there.
What is going on? Did Yummy did something against the Public Mobile rules?
Even some of my posts end up there. No foul language is ever used, no arguing, fighting, etc. Just regular customer assistance.
Ticket has been opened 2 days ago and NO answer at all. Not even acknowledgement ticket has been received.
Could anybody clarify WHY is this happening? Any insight will be appreciated.
2 weeks ago
No idea who you are nor what are you talking about.
I NEVER bravoed you nor have intention to do that. I Bravo only good posts.
2 weeks ago - last edited 2 weeks ago
The reason @Yummy got into trouble was because of the bravos he gave you.
Now that Yummy is banned, you've started using your 3rd account to kudo yourself.
At first I didn't care, I don't care you are same family, same household or even same person. But it is wrong you got me in trouble. Worst is your 3rd account used me and another regular as a shield, but it was still obvious.
People saw the trend and reported all these to @CS_Agent . And sadly because of the number, now I was asked if I was part of your gang. I'm not, I don't know you other than here. It sucks if I ever got banned like Yummy for something I was not part of. So please do me a favor, don't bravo me anymore. You can even remove all the kudos you gave me
Thanks for leaving me alone
05-29-2024 06:30 PM
yes, posts with link might ended up there
and i notice if people posted too many numbers, it might ended up there, probably the system worries people post own phone number or person info
05-29-2024 06:13 PM - edited 05-29-2024 06:14 PM
@hTideGnow Yep those were some that disappeared, it seemed mostly related to having included links or copied and pasted items none of which were offensive, or even duplicates of what someone else said as far as I can see. One included a kimovil link to bands yet other times links there are not rejected. So can they be deleted, or they just stay there forever?
05-29-2024 06:09 PM
@Phil_Adelphus wrote:@Meow I know some posts get moved/rejected because they're repeating what was already said hours before by someone else, but some posts just disappear for no apparent reason, it's happened to me too.
maybe your missing posts are here?
05-29-2024 06:08 PM
HI @Meow
you got the wrong idea. I asked IP because usually when PM blocks someone, they use IP block. Wonder why you can still post
and did @Yummy check here
maybe the post went there
For now, maybe Yummy can create another account and use that to help others
05-29-2024 05:56 PM
I doubt IP has anything to do with Yummy's every post disappearance.
Here is an example what Yummy did today:
Answered post:
And after a few seconds it is gone:
05-29-2024 05:13 PM
Is yummy using a free VPN by any chance? I have seen some sites block the ip from them in the past.
05-29-2024 04:58 PM
Yes, I did encounter the same if by accident I post an answer and then not realizing it post again the same. Warning something like 'flood detected, etc. etc.'
But this is NOT the case. EVERY SINGLE POST Yummy does disappears in few seconds into that area I posted link initially.
What is shameful Yummy did not get any response from PM support (employees) and non of the Oracles cared to comment or clarify my posts.
05-29-2024 04:45 PM
I would hope that using the same IP address or being in the same household is not an issue.
Most of us here are related to each other in some way. Siblings, spouses, parent-child, roommates.
Hopefully this will be fixed soon with reasonable insight.
05-29-2024 11:28 AM
05-29-2024 11:16 AM - edited 05-29-2024 11:18 AM
Ticket has been open. NO response from agent after 2 days...
Being in the same household we do use same IP.
This was NEVER issue before nor I see any restrictions to have same IP for different customers.
05-29-2024 10:24 AM - edited 05-29-2024 10:56 AM
