12-14-2022 08:33 AM
My phone is in the repair shop awaiting a new motherboard Samsung Galaxy S7 Edge and the new motherboard will not arrive until 2023. I looked on this www to see that a series of txt msgs arrived on Dec 07, but alas am unable to read them or reply with a " YES2 " ! What is a siolution for the xmas bonuses in this scenario? #moredataandminutespleasemrbumble 😉
12-15-2022 07:39 AM
In the olden (2020) days, we were able to login to the publicmobile.ca site and go to the add-ons section and manually do it ourselves; as the items were also listed as available for a $0 COST. But alas, this option is no longer available! #darnyouebeneezer 😉
12-14-2022 05:27 PM
PM is still sending text to the rest of the customers. You should get it today or tomorrow If you still not receiving anything tomorrow, you can then open ticket with PM Support and they will add the bonus for you
if you really need to open ticket tomorrow, here are the way to open via Chatbot:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
12-14-2022 05:22 PM
How do I get to the CSA?
12-14-2022 03:29 PM
Once you have the holiday gifts added to your account you should consider suspending your account via lost/stolen. You are putting a lot of trust into a repair shop to have your Sim card and your phone (sans motherboard or not) or consider swapping out your Sim card so you can use it in another phone while you await the repair of your phone.
12-14-2022 09:39 AM
As mentioned above, you can contact customer service agent and explain your situation. CSA should be able to manually process the add ons for you.
12-14-2022 08:48 AM - edited 12-14-2022 08:52 AM
No problem. Just reach out to a Customer Support Agent after December 15, to have it added manually to your account.
Do that before December 31, though 😉.
12-14-2022 08:47 AM
Alas, phone is in shop with SIM in another city! 😞
12-14-2022 08:35 AM - edited 12-14-2022 08:42 AM
Try putting your sim card into another phone so you can still get the text message. Then you can reply when you get it.
Try to reply YES2 to 4911 if you got the text sent to you already.
After December 15, you can also reach out to a Customer Support Agent and ask them to add the Holiday gifts to your account manually. Do that before December 31, though.
