Order in which data used
NeilTownsend
I recently switched to a new plan and since switching noticed my data is drawing off my one time Xmas bonus data and not my actual plan of 3gb per month. It should take from the plan 1st and leave my extra data if I ever go over. I'd like this corrected.
RavingRaven
@NeilTownsend
Monitor your data usage meters in your account on a daily, weekly or monthly basis (decide what's appropriate for you) and take screenshots so you can prove to customer support when data is being drawn from your add on data rather your plan data.
Customer support can replenish this errant usage by adding to the current bonus data add on or they may put it on a new data add on (non-expiring).
I'm having a similar issue along with minor data usage deducting from my bonus data add on while suspended without active service. I'm still waiting on an update from my tech team ticket (3+ weeks). I suggest you ask for a similar investigation and be sure to get the ticket reference # for future inquiries on the status of your ticket.
@NeilTownsend
it shoudn't, but ask ask CS agent to clarify.  Please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗
NeilTownsend
Tried incognito and same issue. Data is being drawn off the add-on before using the data in the monthly plan.
@NeilTownsend In this case, it is likely just a browser cache problem. please check again by using browser with incognito mode
NeilTownsend
I used 1.73 of 9 GB this cycle. My plan shows zero out of 9 on the breakdown. Your suggestion is incorrect.
@NeilTownsend
it still take your regular monthly data first, and only take the bonus data addon if you used up the monthly data.  For  the usage chart, it is designed to show all your data on the same "drawing" there (combined all the available data).  But click the link Usage Breakdown right below the usage charge there and you will see it uses your regular data first and not touching your bonus data
