02-24-2025
12:28 PM
02-24-2025
03:18 PM
computergeek541
Checked my account and can no longer see where all my old Xmas bonus data and minutes are showing on the site. Hopefully I didn't loose them as I was counting on them as backup for me $13 basic plan. Any thoughts, were to look what to check. I was able to find them other times. Thanks
02-24-2025 02:06 PM
Check the PM app, it will show the total of your monthly data plus the More is More data.
I have the 6gb monthly data but it is showing 15gb total.
02-24-2025 12:36 PM
hi @Lar1
just login and click Usage Break down and you should see something like this and those addon will be there
02-24-2025 12:33 PM
@Lar1 Tap usage breakdown and you should see all add ons and what’s remaining
