01-18-2025
03:05 PM
01-18-2025
09:02 PM
computergeek541
SOS I am in need of Mins to get calls and text for work. I ran out today. I didn't get many hours over Xmas break at work. My last pay was not good. I have 5 reward points points. Help!
01-18-2025 09:01 PM
self solution removed
01-18-2025 07:35 PM
@LonesomeLooser wrote:Currently suspended as of noon time today.
If your account is suspended due to non-pay...you have 90 days "grace" from day it was suspended, to pay up and get going again. After that, your PM account is permanently deactivated. If you can get to 7-11 or Shell gas, you can buy payment vouchers, then dial 611 to add those vouchers to your suspended account and resume service.
01-18-2025 03:18 PM
01-18-2025 03:15 PM
Thank you. I thought so. And it makes sense.
01-18-2025 03:14 PM
Hi, account must be activated. Is your subscription currently deactivated?
01-18-2025 03:13 PM
yes, account needs to be active. pay and resume service first. if your account just suspended, then you don't need the addon, you should have calling minutes after account reactivated
01-18-2025 03:11 PM
Thank you, Merci. I saw that and was not sure if I would need my account to be active to use that?
01-18-2025 03:10 PM
5 points are enough to redeem for 500 min Canada-Wide Long Distance
Login the Rewards site and redeem. Pick the minutes addon and add to cart to complete the redemption. The minutes will be added quickly, usually within 5 or 10 mins. Remember to reboot phone
01-18-2025 03:09 PM - edited 01-18-2025 03:16 PM
Hi there, please navigate to your app, then click “Shop Add-Ons” and you can purchase the Canada wide add on for a charge.
Edit: 5 points enough for the add-on, navigate to Rewards page and redeem
