Wrong data usage
Kootenays
Why does my data usage say I’ve used data at 12:27 and 12:28 a.m. Dec 25  when I wasn’t even on my phone? My data billing cycle started today and says I’ve  used about 6mb data when I haven’t. How can this be remedied?
Kootenays
Thank you for the clarification!
@Kootenays @pm updates its usage history 2x a day so your always seeing the last 12 hours used , also PM has cache issue so
Try again incognito/private mode
And or lap top /computer
                    OR
simply try refreshing the page to check data plan / mins / add ons
@Kootenays
PM does not update the data usage constantly.  In fact, it only update it twice a day.
So, any entry you see is just a total usage between that timestamp and the timestamp of the previous entry.  The early morning usage  you see on the Usage log does not mean it was used in the morning but a total usage for the last 12 hours.
Also, for correct usage reading, always use Incognito mode to login My Account to avoid reading cached old info
And for your 6Mb usage,  Public mobile uses about a 5.2mb buffer for your mobile data. This gets reset nightly or when you toggle airplane mode on and turn your mobile data
