Thursday
The Subscription Usage shows that I used all my data 50/50 but when I go into usage history and calculate all the MB and GB for the period of my usage I reached only to 8.5GB of usage. The dates are up to date.
Thursday
And the usage on the My Account front page shows you used all data??
It looks ok from your screenshot, you might want to ask support to confirm what was wrong
please open ticket with PM support:
Thursday
Just adding screenshots from my usage history for the current cycle. Correct me if i'm wrong but I have not reach 50GB...
Thursday
I have iPhone.
And yes, I did go page by page and calculated everything from current cycle 11 June - 11 July and by my calculation I only reached 8.5 GB of usage.
Thursday
I can't use the data.
Thursday
Can you still be able to use data?
if yes, it could be browser caching issue.
Thursday
so, your data is not working now?
if you are using Android, make sure you didn't enable the data limiter, which could have blocked your data usage on your phone
For your data usage, did you use web or app to check?
if using My Account on the web, please use Incognito mode to avoid cache problem.
If you are using app, please be aware that it does not refresh itself, you need to scroll down the screen to force a refresh. Also, the usage on the front page is the TOTAL usage include other data add-on, you need to click Usage breakdown to see this cycle usage
And remember PM uses 30 days cycle. The cycle start date will change and won't be the same date every month you sure you have the correct cycle start date?
You said you checked the usage history, did you go through it page after page to go all the way to the first date of your current cycle? If you downloaded the usage in XLS, did you check if it shows all days in the current cycle? The download has glitch, sometimes it only comes up with a week or two and not the full 90 days usage as it should
