Rewards
06-27-2024 10:18 PM
I lost the $5 loyalty discount I received before the new rewards program. That’s not fair for the people who shows loyalty to the company
Rewards
06-28-2024 12:32 AM
Rewards program is gone and now we get Points. Under that old Rewards program, your loyalty was automatically applied against your regular plan costs every 30 days. As of May, loyalty is now just 10 points ($10) per year AND you have to manually redeem the points yourself. You'll get additional points based on 5% of your regular plan spend. Once your points accumulate to at least 15 points, then you can redeem against regular plan. Here's some reading to do that will help explain the points program. MANY Rewards customers feel the same as you and me...loyalty to PM has diminished considerably now.
https://www.publicmobile.ca/en/bc/get-help/articles/public-points
06-27-2024 11:20 PM
The annual Loyalty under the Points Reward you will receive 10 points (=$10) now.
06-27-2024 11:09 PM
Nothing can be done, it’s how Telus is running the business, every loyal customer has been affected.
If you are on the old $25 1 GB plan, you can change it to $19 1GB plan, so you can save $6
06-27-2024 10:35 PM
Company don't care about loyalty. They just want your money.
06-27-2024 10:22 PM - edited 06-27-2024 10:25 PM
@Lala2023 what plan you have?? $25??
