Will the automatic payment stopped if I switch public mobile to another company
11-30-2024
03:01 PM
12-01-2024
04:26 AM
computergeek541
Payment
11-30-2024 10:59 PM
11-30-2024 03:09 PM
hi @Bryanmao yes, it will
but always good to login and disable it if you are worry
11-30-2024 03:09 PM
Yes, if you port your number over to another mobile company, your account will be permanently closed and you will not be charged.
You could turn off autopayment before you port. However, you can't remove your credit card information without CSA help. But, generally that is not needed.
