11-08-2024
07:53 PM
11-09-2024
03:54 AM
computergeek541
Got a new Samsung S20 but my public mobile is not accepted, it is showing message as unregistered SIM, the same sim works in other phone,
11-30-2024 11:53 PM
Have you been able to use your phone with Public Mobile? Did you contact customer support and request they update their blacklist/remove your device?
11-19-2024 07:50 PM
Already did
11-19-2024 07:47 PM
Yes, that is what I was thinking, Virgin mobile didn’t provide how/who reported that the phone is stolen as the phone was with me all the time and when I provided the invoice, and my ID, they removed it from blacklist.
the only problem is with PM and Telus, and both are basically one company, sims for both these providers are not working but sims for all other carriers are working, I have already tried Rogers, Bell, Virgin, Freedom
11-19-2024 01:32 AM
@s_abbas72 wrote:Yes, it was blacklisted by virgin mobile as the phone was not used within 6 months, I called and provided them with the proof and they removed the phone from blacklist, the phone is now working on other network(tried Rogers and Virgin sims) but it is still showing unregistered sim, seems others companies have the latest information about the blacklisted phones but public mobile list might not be updated that is it is still showing unregistered sim error
Not using a phone for 6 months doesn't mean that it gets blacklisted. A phone normally only gets blacklisted if the phone was reported stolen by the owner.
11-18-2024 11:40 PM
11-13-2024 05:06 PM
@RavingRaven wrote:Unregistered sim message indicates that the phone (and/or that sim slot's IMEI) is blacklisted. Check your device here:
https://www.devicecheck.ca/check-status-device-canada/
Unregistered SIM doesn't have to mean that there is anything wrong with the device. Such an error message would be displayed if the SIM card is inactive/not assigned to an account or if the service on the account has been cancelled. That same error message can also get displayed during times of network issues.
11-13-2024 06:44 AM
11-09-2024 03:56 AM
@Handy1 wrote:@s_abbas72 Is the phone carrier locked ? Where did you get the phone . Is it a bell or Roger’s sim that works in it ?
If this phone were carrier locked, a message asking for the network unlock code would have show immediately upon turning on the device with the SIM card inserted.
11-08-2024 08:27 PM
Your phone might be locked. Who was your previous provide and where did you get your phone?
Your phone might be broken - not having proper connection with the sim card.
Does any other sim, particularly from PM work with your current phone?
11-08-2024 08:20 PM
@s_abbas72 contact Samsung at the number below and ask them for assistance.
1-800-726-7864
11-08-2024 08:07 PM
@s_abbas72 , try doing a network reset to see if that helps.
