Will the 35$ Quebec only Plan work in Ontario?
LK_
Will I be able to receive calls and messages in Ontario with the 35$ Quebec only Plan? I will be spending a few days in Ottawa.
8 REPLIES 8
LK_
Thank you for the tips!
@LK_
honest, it is a new plan with a non common feature "Quebec callings and text",  I don't see much talk about this plan so far
But I believe you should be able to receive incoming calls , most plans have it for free, only some really old plans lack the feature.
But outgoing calls and text could be an issue
Either way, I suggest you to download VoIP app TextNow and use it on Wifi and Mobile Data as a backup to make/receiving calls and text
Maybe the French side of this site has tested things. I haven't read of other reports of peoples results with this plan.
Adding - isn't Gatineau in Quebec?
@LK_ you just have to try and see . My guess it’s province of Quebec only plan . So YMMV
LK_
ok!
LK_
I was hoping to connect to a Gatineau network. And wondering if anyone has tried it before.
dust2dust
We don't know yet for the reality. But in Ottawa you might still connect to Quebec towers. So if you have the plan and go there then please do let us know.
@LK_ @I think you answered your own question the $35 Quebec only plan
Adding @LK_  maybe consider the $20GB for $39 and no problem use anywhere in the country
