09-18-2024 01:31 PM
From Niagara Falls Ontario, I’m connected to 5G+ and no internet is being provided. Very frustrating as I use it at my work. I am just now able to use my phone being connected to a local Wendy’s public wifi.
I’ve tried shutting down phone, switching network (LTE/4G) and still nothing.
09-18-2024 04:16 PM
Hi,
But my friend in GTA just called me saying data does not work either
maybe Bell data outage in the East again
09-18-2024 03:09 PM
Try shutting down, removing your Sim card and then restarting.
09-18-2024 01:46 PM
HI @AK32
no current outage as of now
https://www.telus.com/en/on/outages
but try to reboot the phone first
try to change the network mode to 4G or LTE
and try the sim in another phone if possible
09-18-2024 01:41 PM
Data working fine for me in Nova Scotia. I am on 4G/LTE. If you've already tried restarting your phone, id try an airplane mode toggle (on/off) and last resort to reset network settings (that will remove your saved wifi passwords).
I have seen another member post that they're having network issues too, so maybe there is something going on on Public Mobile's end. You can try to contact a support agent here to make sure everything is fine on your account:
