Monday
Hello! I just switched over and ported my number from Telus. I can make an receive phone calls, and it says I have LTE data but there's no internet connection? Checked APN settings, data is ON, what am I missing here? Furthermore, I can't even login total the app or website on a PC as I keep receiving a Forbidden A1 error.
yesterday
Issue was resolved promptly through a CS ageny. Cheers
Monday
Yes rhe eSIM is working. I am able to make and place phone calls, just no data.
Monday
In the phone cellular setting, is the eSIM checked off?
Monday
I activated with an eSIM with PM and it's currently the only one in use. I have reset the phone app few times now with no success.
Monday
Did you reboot your phone with the PM SIM in the phone. Just power off then back on.
Monday
Thanks for all the replies! I took out my old Telus sim card, reset the phone, reset network settings, reset phone again. Checked apn settings - looks all good. Still no internet. I've reached out to CS agent via PM and will hope they reply quickly! Cheers
Monday
Hey there, i am guessing you received the text confirmation while porting that you had to respond "Yes" to?
If so, your port should be successful. You may have to restart your device, or even reset network settings. and be sure to have only your new sim in your device, so it doesnt try to use your old sim which is now inactive.
Monday
@cnorth86 Check your APN
Monday
hi @cnorth86
Try Reset Network settings
with the login problem, try using PM app or try using Incogito/private/secret mode on your browser
if same, then submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
Monday
remember to remove your Telus sim card or disable the Telus esim , then reboot phone and Reset network settings
