2 hours ago
Hi,
Since morning I can't call or text or even internet is down as well. I am getting full signal and 5g as well but can't seems to work. From Dartmouth, Nova Scotia. Thank you
an hour ago
I am also in Dartmouth, NS and have had no issues.
Would try restarting your phone, toggling airplane mode, and if those dont work, reset network settings (this will make you reenter your wifi passwords, but is a good method to reset network connectivity).
an hour ago
I did the reboot but will try to switch the network mode. thanks
an hour ago
2 hours ago
hi @Iatanvir
no current outage as of now
https://www.telus.com/en/on/outages
but try to reboot the phone first
try to change the network mode to 4G or LTE
and try the sim in another phone if possible
2 hours ago
@Iatanvir There are no outages showing in NS on the Telus outage map so far. Have you tried switching to 4G/LTE?
