11-14-2024
11:18 AM
11-14-2024
08:06 PM
computergeek541
I have unlimited Can -Usa plan , wife only has unlimited Can plan .. if both are in the usa ,, will i be able to call her phone ? I know she will not be able to call me ..
11-14-2024 10:06 PM
Yup, she can receive SMS for free without subscribing to US roaming, but she won't be able to reply or do anything else. She could buy a 15 day roaming add-on that includes calling and texting for as little as $15 though:
11-14-2024 01:25 PM
That's good to know as usually the only reason i would need to txt her is for meet up when we are shopping ...
11-14-2024 01:21 PM
Thx for the advise ..
11-14-2024 12:54 PM - edited 11-14-2024 12:54 PM
Think roaming as cell towers your plan are you on. Canada/US plan will connect to Canada/US towers while in both countries …Canada plan will only connect to Canadian towers while in Canada and not in US. She will need to purchase a US Roaming for service connect to US towers.
11-14-2024 11:54 AM
If wifi is available you could use WhatsApp to call and text each other. Other then that you will need an add on or a local sim to make calls there.
11-14-2024 11:37 AM
hi @Bastian_Vaughan actually without roaming , she can still connect to the 3 US networks and able to receive text. Just cannot send text and no data and no calls
11-14-2024 11:28 AM
@RonnieG No not unless she buys US roaming add on or gets a CAN/US plan like you have
11-14-2024 11:22 AM
Without a roaming plan or add on, she will have no access to the network in the US. Therefore you can't reach her because she will have no signal on any network. Without a roaming plan or add on, she can only use her phone on wifi. You could call her then through messenger, WhatsApp etc but not straight to her phone number.
