Will Umidigi a 13 pro max work on P.M.
Cathy2007
10 REPLIES 10
@softech wrote:
@Cathy2007
Yes, it is compatible
This is the band specifications for your phone, BOLD are the compatible one
4G:
LTE-FDD: B1 / 2 / 3 / 4 / 5 / 7 / 8 / 12 / 13 / 17 / 18 / 19 / 20 / 25 / 26 / 28A / 28B / 66
LTE-TDD: B34 / 38 / 39 / 40 / 41
3G:
WCDMA: B1 / 2 / 4 / 5 / 6 / 8 / 19
FYI, this is what PM needs
However, please note some Umidigi phone could be hard to setup the APN
That problem has been dealt with long ago.  In fact, I have not seen it affect any of the 3 Umidigi phones I have purchased over the years.  I currently have a A13 pro in active circulation which is an earlier edition of the A13 pro max.  Long story short, the Public Mobile APN is in the built in APN configuration file for this phone.
@Cathy2007
here you are
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include dun for hotspot)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
Cathy2007
What is the issue for setting up apn?
Cathy2007
Thank you
HI @Cathy2007
Yes you can
 @Cathy2007   you are current PM customer?
yes, the plan and number ties with the account.  You just need to move the sim card from your current phone to the new phone
Cathy2007
Will I be able to transfer my current number and plan to it?
@Cathy2007
4G:
3G:
pmva
@Cathy2007 I don't see why not.  This phone is current, supports nano SIM and supports bands of 3G/4G LTE that PM uses.  I think you should be good.
HI @Cathy2007
it should work according to the band spec on the site
