Data not working
Nancyjb98
I purchased some data. But it says U.S data roaming 3G etc. how do I fix it. I’m out of data I’m in canada and need more data.
@Nancyjb98
Hmmm, curious why it would say US Roaming? Are you at a border city?
@Nancyjb98   Login to My Account using Incognito mode, go to Payment page and confirm if you have really got the US roaming data .  If you want regular data to use in Canada, you should have got the 1GB add-on for $15 or 200MB addon for $5
No worry, if you have got it wrong by mistake, very likely PM support would be able to help and switch it for you.  Just engage them by Chatbot
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
