4 hours ago
3 hours ago
To turn off Live Voicemail on your iPhone, open the Settings app, tap Apps, select Phone, and toggle off the Live Voicemail switch.
To disable the "Take a Message" feature on your Google Pixel, open the Phone app, tap the More menu (three dots) in the top-right corner, select Settings, tap Take a Message, and toggle the switch to the Off position
3 hours ago
@Budgie15 wrote:Why am I getting transcriptions instead of voicemail recordings?
Hello @Budgie15
If you're seeing text like transcripts instead of standard audio notifications, your phones operating system may be the reason.
For Apple, it's Apple Live Voicemail. It's a feature in iOS 17 or newer.
For Android, it's a built in tool like Call Screen or Samsungs "take a messages".
If you press and hold on to 1, it should go to voicemail and you can hear them there.
4 hours ago
You have iPhone Live Message or Pixel Live Message turned on. Disable it and reboot phone will change it back
