Help contact support
Roysphone
How to get support for network not connecting and locked out of account/doesn’t recognize phone/email.
@Roysphone
Dial 611 to check the status of your account. If it is active and not suspended.
If it is active then there could be an outage in your area.
https://www.telus.com/en/bc/outages
If it is suspended then you need to make a manual payment.
slusagm
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
Chalupa_Batman
Hello @Roysphone
If you're locked out of your account, you can get PM to help you reset it.
