09-23-2024 12:41 AM
Hi,
I redeemed 3gb data for 15days for 15credits. It's been more than 2days and my data is not working.
09-23-2024 09:46 AM
Thanks for your response.
09-23-2024 09:33 AM
09-23-2024 01:42 AM
@Zoyakhan1 wrote:Yes the data was working previously. It's showing in my account that it's been 2days this plan is activated.
I've just realized that you have purchased a roaming add-on. Are you trying to use this add-on while you're in Canada? Unfortunately, the 3GB data add-on can only be used while you're in the United States.
09-23-2024 12:58 AM
09-23-2024 12:48 AM
@Zoyakhan1 wrote:I redeemed 3gb data for 15days for 15credits. It's been more than 2days and my data is not working.
A couple of questions: Was the data previously working on your device? And, is the add-on showing up in your account?
If you've never used data before this could be a phone settings issues, specifically with the APN settings. Please compare to the settings at the following website: https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
