Will US roaming work for me?
02-27-2024 11:47 AM
Phone is Galaxy A8 2018. No VoLTE I believe.
Will voice work?
Is PM still using 3G for voice roaming in the US?
Will texting work?
Will data work?
If so, I can use WhatsApp.
Thank you!
Add-Ons
02-27-2024 01:44 PM
HI @Irina_O
you are lucky, US has cheaper phones!! 🙂
02-27-2024 01:43 PM
> Upgrade your cell to a volte enabled phone before going to US. Prob solved !
Thank you for volunteering to pay for it.
02-27-2024 01:15 PM
@Irina_O wrote:And yet, PM still sells voice roaming that works on 3G/2G only.
Sounds scammy.
02-27-2024 12:48 PM
Sounds scammy.
02-27-2024 12:33 PM
T-Mobile is shutting down their 2G network on April 2, so there'll be no options any more for non-VoLTE phones in the USA since 3G was shut down in 2022.
02-27-2024 12:17 PM
02-27-2024 12:05 PM
@hTideGnow wrote:HI @Irina_O
yes, voice will work on 3G
Text will work, only phones older than 2015 might have problem
Data will work for sure. Since data work, Whatsapp will work too
It's my understanding that the 3G network in US has been shut down, no longer available. Without a volte enabled phone, customers phone must be able to drop to 2G to complete their call and only on the T-Mobile network.
02-27-2024 11:56 AM
HI @Irina_O
02-27-2024 11:56 AM
@Irina_O wrote:Phone is Galaxy A8 2018. No VoLTE I believe.
Will voice work?
Is PM still using 3G for voice roaming in the US?Will texting work?
Will data work?
If so, I can use WhatsApp.Thank you!
Everything will work EXCEPT w/o a volte enabled phone, calls will be using their 2G system. It's not great but that's what is available for talk. Consider using a VOIP app such as textnow for talk in US...it uses your free wifi available in most motels, cafes etc.
