Wifi Calling
Mohawk44
Does PM support wifi calling on an iPhone? Don’t see the option for it.
9 REPLIES 9
Mohawk44
Will have to try 3G and see if that’s better on my iPhone
HI @Mohawk44
from your old posts, I see you have iPhone SE 2022, it has VoLTE and PM has enabled it now by default.  However, try to change back to 3G and see if it helps when you are home, some find 3G voice is more reliable still
Mohawk44
I get good signal in my town except for when I am at home. That’s the only reason I was looking for wifi calling.
dust2dust
Follow the money. And not just iphones. Although the Public iPhone Mobile company might introduce it for iphones for all we know. 🙂 Providers make heaps of money on roaming. Wifi calling bypasses roaming and therefore they lose that revenue stream. Yes it's for those that can get by waiting to connect to a wifi access point but really, can't we all?
@Mohawk44  No sorry you need to look to Koodo or Telus for that feature
HI @Mohawk44
no wifi calling here.  If it is something you need , due to poor reception, you need to go with Koodo or Telus
Phil_Adelphus
You would most likely have to go to a postpaid service rather than prepaid to get wifi calling.
hairbag1
@Mohawk44
not supported here in Public Mobile world...yet.
TextNow works as long as you have a wifi signal or you can use your data for it too.
JRod
@Mohawk44
Unfortunately wifi calling is not supported currently at Public Mobile.
