03-05-2025 10:41 AM
I only have the 250mb plan but ran out so I added 1gb add-on. I went to check my data usage and it shows unlimited. Can someone please explain? Thanks in advance.
03-05-2025 11:22 AM
Looks like a bug... don't expect it to last!
03-05-2025 10:49 AM - edited 03-05-2025 10:51 AM
THAT is very interesting!!!!
I have the same plan and it shows as per my plan... NOT unlimited. Did you try to see usage using computer? Mine screenshot is from computer, not an app.
Did you try to use all your 250MB to confirm it IS unlimited after 250?
