Why are incoming calls listed private number. How do I change this
norm144
10 REPLIES 10
@norm144
The caller has paid for an unlisted number.
PM does not have an option to force call to dial *82 in front of the number to show the caller ID.
Bell landline or cell? What about Rogers/Fido/Chatr? Or even Virgin/Lucky under Bell? Or try calling from a voip service.
HI@norm144   If all Bell customers have issue showing up the phone number, then it could either be PM's or Bell's problem
Start with PM , open ticket with CS agent and see what they say.  You might later need to ask a Bell friend to open a Bell ticket as well.  But start with PM
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
norm144
Calls from any bell customer to my cell. My wife and myself public mobile see name displayed. Friends on bell show private number. I know they are not blocking me.
dust2dust
There was a customer that had a similar problem a few days ago of landlines showing as private number. Are you getting calls from a landline? Or is this all calls from any service?
HI @norm144
People just hide their number
If it is professional spam caller, they have system to automatically hide it
Normal users can also dial *67 before calling the number to hide it on the caller id
@norm144  That’s has to do with caller having there number being private . You can make yours that way if you choose too .. my experience thou is once you do no one answers your call
Yummy
Most likely because callers decided not to provide number. Nothing to do about that...
@norm144  sorry, not something you can choose.
When a person call something, they can choose to hide the phone number.   If they have chosen that, the one receiving the call cannot do anything to retrieve the number
Metal1967
@norm144  That’s the callers choice to do that.. you can’t change it
