fix line service
PARM-HIRA69
i change device ,but line disconnect when i recived calls incoming and outgoing calls ,check line service
@PARM-HIRA69
It could be an outage in your area so check the outage map:
https://istheservicedowncanada.com/status/telus/map
hairbag1
@PARM-HIRA69
what steps did you take to change your devise ? Usually, you merely remove sim from old devise and install that sim in new devise. What did you do ?
Sansan
@PARM-HIRA69  you can reset your networks to see if that might help.
