What's the easiest way to see data usage for a 90 day range?
-LukeKD-
I've got the 90-day subscription going and it's been fine but I was wondering how much data I actually use over the last 90 days? When doing a "usage history" inquiry, there is no specific "data use" only filter (or Texts or incoming or outgoing for that matter).
When I attempt to download the XLS file, it only downloads one page... of the 28! This is ludicrous as the site loads so slowly, downloading each of the 28 pages will take days!!! I haven't a clue how to make this an easy process, help me PM community you're my only hope!
2 REPLIES 2
-LukeKD-
Drats...
I have the 90-day and it just renewed so now my data shows no usage.
Where does one make a "feature request" here?
HI @-LukeKD-
the filter might work but the download will only download 7 days of data 😞
do you have a 90 days plan or 30 days?
if you a 90 days plan, the data meter on the overview page should be good enough
if you have a 30 days plan, then there is really no good way to get usage older than your current cycle other than going back to Usage history page and go through it one page at a time.  I think filter works, so you can filter out data and go through one page at a time and sum up
