What's included in the US Roaming plan?
iamnopreacher
Hi,
I would like to know what's included in the talk+text+data US Roaming plan? Are there any limits on talk minutes or number of texts?
Thanks,
Derrick.
iamnopreacher
Thank you guys. Much appreciated.
HI @iamnopreacher
No limit with Talk and Text.
But US started shutting down 3G network and it might affect the coverage for Talk.  I believe you will still get decent coverage for voice in US, but it is possible some area might have problem with voice calls
But text and data will work fine without any problem
DDM69
Meow
Only data is limited based on number of bytes bought. Calls/SMS are unlimited for 10 days.
MrSpock
@iamnopreacher hi no for 10 days talk and text are unlimited data stops after 250 mb
@iamnopreacher   With the roaming Talk+text+data, the talk and text part are unlimited for Canada and US.    But the data is limited.  The add-on itself is 10 days , 240 hours expiry and will start counting from the moment you successfully purchased
