Canada-US Promotions
robandsue
Does the current promotion for 75 gig 5g titled "Canada-US promotion" include data roaming in the US?  I have a plan that allows for US roaming, I saw the offer, and signed my wife up, but after purchasing, the description doesn't specify US data like the description in my sub does.  It is a bit misleading if US roaming is not included in the "promotion"
robandsue
My example doesn't indicate Can-US data in the body!  Thanks for the info!  Attempting to contact a live agent is an exercise in frustration!!
@robandsue
make sure to enable Roaming Data when in US. Also..make sure you both have volte enabled phones for best talkability while in US.
Sjohnson30
Check the notes ++ specifically. It's not clearly worded but yes that plan does allow voice and data roaming.
robandsue
Thanks.  I was confused because my plan specifies Canada-US data, and the new plan I signed my wife up to does not in the description despite the fact the the "Title" does.  We are heading to  Florida for a couple weeks and I don't want to get dinged for unexpected roaming costs
robandsue_0-1709051753000.pngMy plan
Her plan
PM_5G
I had similar concerns / questions about the Canada / US Promotional Plans...
Collected all the info and posted clarifications I received about this...
Click below and many of your questions should be addressed and answered!
**** !!! Click Here and Check out My Post on Canada / US Plans !!! ***
TheSterlinger
If a plan says Canada-US that means you can use it in both Canada and US without having to pay for roaming. So you will be able to use data, call and text while in the US.
