03-16-2024 12:12 PM
03-16-2024 04:50 PM
I just have to ask.
Do you have roaming turned on for Public Mobile SIM? It has to be on.
03-16-2024 04:10 PM
@hTideGnow I wonder if it's an iPhone thing? I've never had an android automatically connect to Verizon where Public Mobile is the service provider.
03-16-2024 03:47 PM
hi @ejohan Verizon is not a PM. roaming partner
Phone usually picks the strongest signal, so I always use manual network selection when I travel
03-16-2024 03:46 PM
Verizon is not a roaming partner for PM. Only T-Mobile and AT&T work, but AT&T 5G does not. Configure your connection settings accordingly.
03-16-2024 03:40 PM
@ejohan It is AT&T that is problematic on 5G. Public Mobile has two roaming partners in the USA, AT&T and T-Mobile. Although sometimes phones automatically pick Verizon, there is no roaming agreement with Verizon which is why it didn't work.
03-16-2024 03:31 PM
I’m currently in the US, and 5G is working on T-Mobile. But it didn't work on AT&T, only LTE. However, Verizon didn’t work at all, and that was the network my phone had initially automatically picked.
I have a 5G Canada-US plan with Public.
03-16-2024 12:56 PM - edited 03-16-2024 12:58 PM
Change to 4G preferred on your device. 5G AT&T doesn't work.
Edit: Just realized you said text and data work. It's probably a lack of VoLTE, as @fixin mentioned. What phone are you using? The US no longer has a 3G network to make calls on, so without a VoLTE phone you can't make calls (unless you manage to find a 2G T-Mobile connection).
03-16-2024 12:34 PM
Hello @paddy1
Which phone are you currently using while in the US? That may help a bit more to understand and help you.
03-16-2024 12:18 PM
@paddy1 - Most likely your phone isn't VoLTE compatible on PM SIM. Manually switch to T-Mobile and chose 2G / EDGE / GSM and that will make the Data speed slower but be able to make calls and send texts.
03-16-2024 12:16 PM
You can try to manually select either T mobile or AT&T. Choose LTE (instead of 5G). Enable roaming.
If that does not work, reboot phone. Or network reset of phone (this will erase any saved Wifi settings).
https://www.publicmobile.ca/en/ab/get-help/articles/us-roaming-troubleshooting
03-16-2024 12:16 PM - edited 03-16-2024 12:23 PM
Critical part to US roaming depends on T-Mobile/AT&T coverage and whether you can connect successfully onto either network.
If the phone is not connecting to T-Mobile/AT&T, change the Network Connection from Automatic to Manual and select and test both T-Mobile and AT&T and see which one you can connect.
If your issue is with voice, make sure VoLTE is enabled on the device setting. And if it does not work, try to change the Network to T-Mobile ONLY, and change Preferred Network Type or Network Mode to 2G and see if the calls go through.
Also, you can download VoIP app TextNow as a workaround to make calls and text if you have Wifi or if your roaming has data component and data is working
03-16-2024 12:16 PM
HI @paddy1
are you connected to T-Mobile or AT&T? if not, try to manually connect to them and test.
Also, turn off 5G, use 4G
