What does Unlimited Canada-wide Talk mean?
05-10-2022 08:40 PM
I have the $25 for unlimited Canada-wide minutes + 500 MB data plan.
If the plan says unlimited minutes, then why am I getting "you are low on minutes" or "you just have 10 minutes left" notification? Does unlimited minutes mean unlimited minutes for the entire billing cycle?
Plans
05-11-2022 11:10 AM
Yeah just context on why not to be alarmed on messages that don't make sense to them, sounds like they weren't aware it is somewhat prevalent
05-11-2022 04:47 AM
If you don't have a payment card to enable autopay to get the extra 500mb autopay data bonus and you pay by voucher I can help you with a visa gift card with a $0 balance. You will be able to register it for autopay and recieve the data bonus you just have to continue to pay by voucher as autopay would fail if tried to charge the card. Send me a private message if that would help you out.
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info
05-10-2022 11:55 PM
Hi @JL9 are you answering OP question or just try to type something?
05-10-2022 11:35 PM
Lots of message seem to go out erroneously unfortunately, usually re:mins, data or expiring cc. You should be good to go, just a bit of nuisance.
05-10-2022 09:30 PM
@ruhivik28 - as long as you can get the calls to complete, by adding "1", then you can safely ignore that message.
If you cannot complete the calls, try performing a reset of your network settings on your device.
This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before.
Iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
android:
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
05-10-2022 08:56 PM
If you are not on the $15/ month plan. The message might be sent out by mistake.
05-10-2022 08:56 PM
HI @ruhivik28 did you reboot your phone?
this is a common glitch with PM. Usually a device reboot will clear it up
No worry, keep talking 🙂
05-10-2022 08:45 PM - edited 05-10-2022 08:46 PM
@ruhivik28 Yes, it's unlimited mins/texts across Canada except for the $15 plan (edit: which has 100 outgoing mins). You shouldn't be getting that recorded message saying you have 10 mins left on the $25 plan. You might need to add 1 in front of all your calls even if local, but your call should complete regardless. You get 500MB bonus data when you add a debit Visa/MC or CC to your account.
05-10-2022 08:42 PM
If you are on the current $25 plan you have unlimited calling in Canada. Log into self service to confirm your plan.
![](/skins/images/97D9FB88C915001D8DAED89DBB2650DF/responsive_peak/images/icon_anonymous_message.png)
