03-21-2025 04:48 PM
Hello! I just transferred to Public and I got a text message saying “welcome to Koodo” I was advise to send a message here for someone to look into it .
thanks
03-21-2025 05:22 PM
@Laurati wrote:Hello! I just transferred to Public and I got a text message saying “welcome to Koodo” I was advise to send a message here for someone to look into it .
thanks
Ha. It seems Public Mobile may be having an identity crisis with that text message. Honestly, I wouldn't worry about it too much. As long as your phone works with calls texting and data, you should be just fine.
03-21-2025 05:21 PM - edited 03-21-2025 05:23 PM
Test your calls and texts in and out and your mobile data. If everything works, just ignore the message. If there are issues that you cannot fix, you may need to message a customer agent. Good luck.
03-21-2025 04:56 PM - edited 03-21-2025 04:57 PM
PM and Koodo both owned by Telus, so, it might sent by mistake with wrong name. Important question is , does your Public Mobile sim work?
Or you can ask PM to check. just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
