90 Day Subscriptions?
Chris_
Hi there,
So I've noticed something over the years about getting a discount if you use a 90 Day Subscription.
- How do I set that up?
- Is that an option available with any plan, or only select plans?
- How may rewards be affected, or will they still be the same as if on a monthly?
Thank you
11 REPLIES 11
on2wheels
Is there somewhere we can provide feedback about the way the site is setup with regard to 90 day plans?  To Chris's point the 'change subscription' page doesn't show whether a plan can be paid every 90 days UNLESS you manually check each plan.  It goes without saying this is tedious and not user friendly.  This is the feedback I want to give PM.
Chris_
K thanks for clarifying.... now I have a decision to make... do I care about having a 5G plan, or do I hop on that 4G plan to gain another 15Gb? Hmmm 🤔
@Chris_  No not every plan only some and it will say so in the plan description, but currently none show on the website just in our accounts as targeted offers .
Chris_
You mean, if I were just starting out, activating a new account, a new customer, that I would see the 90-day option for ANY of the plans?
@Chris_  Yes and yes , there are so other plans that were added for 90 days plans but you need to be in the $13 plan or $15 plan to see them
Chris_
OK thank you. Is that 90-day only available on that 1 plan right now? That's the 4G plan, right?
Chris_
OK, I get it... You're lucky "if" you even ever see it as an option... 😉
@Chris_  In your account change subscription  you need to select the 65GB $45 plan and once you selectd it you should have option for 30 days $45 or 90 day $34 but for 90 day you need to lay $102 upfront and you will get 195GB to use river the 90 days to average $34 /month
@Chris_ wrote:
I can't find in my account where/how to change from 30 to 90 days.
That's some of what I'm asking. Is the 90 Day option something anyone can do on any plan?
The option is only available IF offered at the time of signing up for that plan. It can't be changed to a 90 day plan after the fact.
EDIT. If it's a current plan you're on, no ability to change. HOWEVER, if it's a NEW subscription, when you go to check out the two options will be there.
Chris_
Chalupa_Batman
@Chris_ wrote:
Hi there,
Thank you
Well @Chris_  it really depends. Sometimes it's not "shown" up front there is a discounted price if you get 90 days as some have reported and have just stumbled upon it. Sometimes they are offered only to new customers. But I will say this. If you have the $34 Can US plan with 50GB, stay on it. It's a wicked deal.
