Voicemail issue
Katievry1
I can't listen to my voicemail because it doesn't recognize when I press 1. help!
@xmx wrote:
Send private message to CS_agent to check for you. below is the url
There's several things to suggest and try before sending message to CSA for their help. Not that you're wrong...just to prevent unnecessary PM resouces, wise to try other fixes first.
xmx
@Katievry1  Reboot the phone , also can you test the SIM card in another phone to test ?
HI @Katievry1
you meant press and hold 1 does not dial to VM?
try to click Reset All networks and it will program the key
if that does not work, go to Dialer, settings and manually program this to voicemail number
778-580-4001
hairbag1
@Katievry1
what happens when you dial your own number ?
