Account Overcharged
serrivmo
Hi, I changed my Subscription to a lower level but still got charged for the old subscription. I tried to put in a ticket but get an Error XXX code, I did everything asked but cannot submit a ticket. How do I speak to a Billing representative?
8 REPLIES 8
serrivmo
Hi, thanks for all your help. I'm sorry for the delay in replying. I had an unexpected visitor from out of country. I was reading the billing wrong so all is well with this issue.
@Rag2  Use this direct link to support
send a  private message   To CS_Agents click
Rag2
I am having the same problem
did you get it resolved
dust2dust
Do you see the overpaid amount in your balance? The difference between the old plan and the new plan? If so then just leave it there for your next renewal.
Chalupa_Batman
Hi @serrivmo
The only thing I'd like to add is if you changed your subscription during the middle of a current subscription and had it start right away or even start it the next day or so... there would be a double charge. Hence the reason why we always suggest starting it on renewal date. The 3 links below will get you to a Customer Support Agent to further assist you. Good luck.
hi @serrivmo
submit a ticket here
And did you make the plan change using Change on Renewal After the plan was renewed??
@serrivmo  Did you not change plan on renewal or  do immediate plan change ? If so that’s why and no refunds . Otherwise here’s link to support
Phil_Adelphus
Send a private message to customer service by clicking here
