01-14-2023 01:30 PM
Hey, I can’t access my voicemail. When I go into it on my iPhone, I get an “Error Performing Request, Unknown Error” error. Does anyone else have this or know how to fix it?
01-14-2023 03:10 PM
I found this in an older thread from here, give it a try. Enter all of the following into the dialer and tap the “call” button:
*5005*86*+17785804001#
01-14-2023 02:25 PM - edited 02-17-2023 08:28 AM
Hi @Merisusa7
This error could be just because a network problem in your area.
Try calling thr VM access number directly, you can try this one: 778-580-4001
try calling VM in different area
or you can try to change the network to 3G on your phone
01-14-2023 02:20 PM
Presume you tried this, @Merisusa7
What happens when you try to access your voicemail from another phone:
01-14-2023 01:40 PM
@Merisusa7 @Also check your phone app and make sure it’s on you will know it’s on if you have an option to change voice mail password , otherwise toggle it on
01-14-2023 01:39 PM
@Merisusa7 - was voicemail working previously?
If not due to an update, try performing a Reset of your device's Network Settings. This also resets Wi-Fi networks and passwords, cellular settings, VPN and APN settings, and connected Bluetooth devices that you've used before.
Iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
01-14-2023 01:35 PM
@Merisusa7 @It’s n iOS issue are you on the latest update 16.2
