error performing request unknown error fail. iphone voicemail.
Malch
I searched for an answer for months. Got this error when I press the voicemail box.
I found the answer today, in this forum!
geogolem in 2016 pointed to Rogers. His link doesnt work any more but searching for iphone and voicemail will bring it up.
##5005*86#  delete number (doesnt work)
*5005*86*+17785804001#   set number  This works .
7 REPLIES 7
@Timer wrote:
@Malch
How To Use  Voicemail Features (publicmobile.ca)
turn off device and turn back on and tried to call your number from same device.
and check your  Voicemail Access Numbers - (publicmobile.ca)  by @Nezgar
The customer wasn't asking about how to use voicemail or for voicemail retrieval numbers.  The customer was sharing some findings.
Timer
@Malch
tried to do some troubleshooting,
How to > Reset Network Settings
and  Switch to 3G
Update iOS > Go to Settings > General > Software Update..and rebooting device.
Malch
No error with a Telus SIM in it.
Same error on a iphone 5c SE 6s with public SIM.
Proof that searching the community for answers can help! 🙂
Glad you got it figure out @Malch
@Malch was it because your iPhone wasn't set up with the proper VM number earlier?  This step basically set the number back, right?
Thanks for sharing 👍
Timer
@Malch
