VoLTE Plans?
Priority
Which plans are compatible with VoLTE? On the 4G Plans, everytime a call is made it seems that it switches from LTE/4G to 3G and the speeds get way slower during that call, making it impossible to even just scroll the internet or load Facebook.
8 REPLIES 8
@Priority other than iPhone, PM list only allows phones within the last 2 years on VoLTE
@computergeek541 wrote:
@Priority wrote:
This will also give accurate results for the Public Mobile Compatability?SmartSelect_20230720_204734_DuckDuckGo.jpg
The  Telus compatibility check cannot be relied upon for checking VoLTE capability at Public Mobile. There are mistakes in the database and there are also some devices that are currently being used on VoLTE at Public Mobile that aren't even in that database.  It's meant as a preliminary guide only.
If it is not in the whitelist, it won't work.  If it is in the whitelist, it might work.
I think Telus VoLTE program pretty much open to all mainstream phones that have VoLTE,  at least most phones sold in Canada, not imported phones.
I think the PM"s shortlist is literally a short list by comparison
Priority
will13am
@Priority , Telus runs a pretty restrictive whitelist for VoLTE.  Use this VoLTE checker to see if your phone is on the whitelist.
https://www.telus.com/en/support/article/how-to-use-volte
Priority
I am using a Samsung Galaxy Note 20 Ultra with e-SIM.
It is Compatible and working with VoLTE on my Bell e-SIM but not the Public yet. I might have to use it for longer, maybe It's because I'm in the basement and so it just wants 3G instead of LTE for calls regardless using Public since I am on a 4G plan with Public and 5G Plan with Bell?
hairbag1
@Priority
volte is available on all PM plans BUT only PM controls which phones they'll enable it to. Which cellphone do you use ?
