12-27-2024
05:14 PM
12-27-2024
11:41 PM
computergeek541
Guys finally Up and running. However, the very thing i was looking forward to was fast internet. What’s the issue?
How do i fix this? I am based in Coquitlam-Vancouver, BC, Canada
12-28-2024 09:06 AM
@prajwalsimilarily to a physical SIM card, eSIMs can only be used once so you won't be able to use the same QR code to set it up again but you can purchase another eSIM through the Public Mobile app and it should end up as $0.00, if not an agent will credit you the amount back, but ordering the new eSIM should send you another email with a QR code (if you decide to go down this route).
Something else you can try if you have access to another phone and if you end up getting a physical SIM, is try testing the PM SIM in the other phone to see if it's getting the same speeds. If you are still with the eSIM you would need to install the PM app on the other phone and order an eSIM on that phone and go through that whole process which is more of a pain
12-28-2024 01:04 AM - edited 12-28-2024 01:05 AM
Oh that sucks. The QR given at registration does not work either, cannot add as sim. I believe it is a setup issue and not device issue. I just bought a new device to upgrade my plan.. even though i know it’s just 13 pro max
12-27-2024 08:05 PM - edited 12-27-2024 08:10 PM
If I recall correctly you have to "buy" it again but I believe they will give you a credit to make it "free".
12-27-2024 07:46 PM
Freedom gives it in its account after doing imei check. Where is it for Public mobile? I cannot see anywhere
12-27-2024 07:45 PM
do you know how to obtain working QR for esim? If i delete it i dont have QR to install it again, the. i have to purchase esim again and again. I think the working QR for esim will fix this
12-27-2024 07:39 PM
Will do. I have ordered it its on the way
12-27-2024 07:26 PM
@prajwal maybe try reseting your network settings see that helps , could buy physical SIM card and sim
swao the number in your account and use the physical SIM card instead of eSIM which I think most people here in community prefer physical sim over esim for various reasons
Find SIM card Find a store near to you | Public Mobile
Amazon
$4.99 at Amazon right now too BTW
12-27-2024 07:17 PM
LTE doesn’t work as well. There’s something wrong nobody seems to be able figure out. There is no way i have to live with less than 1Mbps speed with 5G, there should be something i have done wrong please let me know what is it 😩
12-27-2024 06:38 PM
You are in BC. The Telus network is known to be spotty in some areas. Perhaps give LTE a try instead of 5G.
12-27-2024 05:36 PM
At least you get to see 3 digits mostly. Look at this, can you believe this. Li doesn’t work
12-27-2024 05:21 PM
@prajwal @It’s frustrating for sure speeds are up to 250mbs 5G with public I have Telus line with 5G+ and have gotten similar results before it’s always changing and many factors network congestion area your in environment in basement big building . I do t advise you chew thru your data doing lots of speed test but do try in direct areas and times a day .here check out some of my results I have only 10mbs one day too but phone was still working fine , nothing to worry about
