10-31-2022 05:16 PM - last edited on 10-31-2022 06:49 PM by computergeek541
When i try to log in to my account i can only get the Verification code by Email now its not giving me the option for SMS and i am not receiving the email for the verification code
10-31-2022 05:56 PM
@dabr Probably feeding the sugar addicts..😂
10-31-2022 05:55 PM - edited 10-31-2022 05:56 PM
Are you sure the trick or treaters are to blame? Or is it the sugar high and your imagining the all the goblins and ghoulins are diminishing the treats in your bowl?
10-31-2022 05:53 PM
Well we're still awaiting a response from OP as to if it is or not suspended.. 😊
10-31-2022 05:50 PM
Ok.. my bad.. I’ll blame the trick or treaters..😬
10-31-2022 05:35 PM
If OP's account is suspended, then the 2FA is only available via email, so until they're able to login, they won't be able to toggle that option off.
@GerryP Is your account suspended?
10-31-2022 05:30 PM
Well you can login but you are stuck in the verification page if you can't get the code?
10-31-2022 05:24 PM
@treefrog They stated they logged in and could only get email verification…….so they logged in…
10-31-2022 05:21 PM
How is the OP supposed to log into their account if they don't get the verification code to login?
10-31-2022 05:20 PM
@GerryP If you can log in.. you can change where verification gets sent.. to do step by step will take lots of typing…😬
10-31-2022 05:19 PM - edited 10-31-2022 05:20 PM
Are you currently suspended? If you are you can also pay by public mobile voucher through 611 on your phone. Once activated you can then get the verification code sent by text message.
Edit: Or if you know your 4 digit account pin number you can pay with your credit card through 611.
