VOLTE
Divit2
Heading to the Us this weekend and plan to purchase us roaming. Received sms on VOLTE upgrade. Once addon is purchased how will activate VOLTE?
10 REPLIES 10
dust2dust
Was that text a positive compatible or not compatible?
Do a full power off restart of the phone. Then go in to mobile network settings to see if the toggle shows up. It might not. Go in to sim card status and look for IMS registered. It might not.
@Divit2   we don't have any feedback about people able to use S8+ with VoLTE on PM yet.  But yes, S8 should have VoLTE.  So, you will have to check the settings when you are in US
Worst case, try the voice in 2G and see if it works.  Some people able to use 2G without problem.
and in case you cannot use voice with success, open a ticket with PM after and they usually would do something to compensate
Divit2
Much apreciated
Divit2
Thank you
Divit2
Samsung Galaxy S8+
hycm53
Enable your phone to VoLTE or LTE first. I'm now in US, $30 for 15 days add on works excellent.
@Divit2   what phone do you have?
Divit2
Thank you ... There does not appear to be anything in my profile for this?
@Divit2
Your VoLTE might or might not work in Canada yet, but should work in US if PM already enabled your VoLTE on your profile
before you go to US, enable VoLTE on your phone first
iPhone:
Tap Settings.
Tap Cellular.
Ensure the Cellular Data switch is in the “on” position.
Tap Cellular Data Options.
Tap Voice & Data.
Ensure 4G or LTE is selected (has a checkmark)
Android
At Settings,  Select Connections-> Mobile Data->Enable VoLTE
