03-14-2024 08:55 AM
03-14-2024 11:02 AM
Download Airalo.
03-14-2024 09:03 AM
@rtang - Public Mobile only has roaming in the United States but you can buy an Airalo eSIM (If your phone supports it) or buy a local SIM card.
To make calls and send texts - use Fongo or TextNow. They will hook you up with a local number from anywhere in the world.
03-14-2024 08:57 AM
@rtang Sorry public mobile only has roaming in the US with roaming add on . You be best served to buy local pre paid SIM card in turkey for your trip
