04-19-2024 03:48 PM - last edited on 04-20-2024 02:34 AM by computergeek541
Hello,
I just bought a bundle for talk and text and 3 gb to use in the US that lasts 15 days. Do i need to turn something on in my phone or do i just keep using my phone and the data normally like i do when i am in Canada?
I have an android phone and see in Settings > Connections > Mobile Networks , there is a switch called Data Roaming. Does this need to be flipped on once i am in the US?
Gavin
04-20-2024 12:31 AM
@gavinhee2 It lasts for 360 hours from the time you purchase it. You can come and go as many times as you like within those 360 hours.
04-20-2024 12:23 AM
thx. does the 15 days last even if i leave the US and come back in within those 15 days? i plan to go tomorrow to test things out but my trip isn't till the following weekend.
04-19-2024 10:57 PM - edited 04-19-2024 10:57 PM
On your phone in your network/sim settings:
1) Turn data roaming ON
2) Set Preferred Network to 4G/LTE (not 5G, because AT&T 5G doesn't work)
3) Ensure you're connected to AT&T or T-Mobile. If it doesn't connect automatically, do so manually.
4) For phone calls you need a VoLTE compatible phone:
04-19-2024 03:54 PM - edited 04-19-2024 03:54 PM
@gavinhee2 Yes you need to turn data roaming on. Hopefully you're going soon because the 15 days starts from purchase.
04-19-2024 03:50 PM
HI @gavinhee2
what phone you have?
try VoLTE by manually connect to AT&T and T-Mobile, leave Network mode to Automatic
if still no talk, try manually connect to T-Mobile again but change network mode to 2G
