07-18-2020 05:43 PM - edited 01-05-2022 12:09 PM
I have the 50 dollar plan. Im just to clarify if i can call Canada from the us.
07-19-2020 08:36 AM
@Pawprints1986 wrote:@Triguy your post makes me wonder, so if say in a non covid world you're going to be gone for 19 days, it will not let you purchase 2 add-ons and have it automatically start the second one when the first one expires? Just seems odd is all... 611 likely won't work over there to add that way and if you can't find WiFi anywhere for some odd reason... You'd be Sol?
611 and 18554public will work in the states. You also can't buy two of the same add-on concurrently. You can buy different quantity data but it gets rather confused with multiple talk add-ons.
07-19-2020 07:15 AM
@Pawprints1986 Add ons always start when purchased.
07-19-2020 05:43 AM
07-18-2020 06:46 PM - edited 07-18-2020 07:13 PM
Thanks for the solution @Ericsparrow56 but it should go to @gpixel 's original answer, since it answered your original question. Someone looking at the question and my answer later will only be confused. Please use the 3 dots on the top right of your post to remove the solution and to give it to the one mentioned.Stay safe.
@computergeek541 , @Luddite , @ShawnC13 oracles. Please reassign the solution.Thanks.
07-18-2020 06:38 PM
@Ericsparrow56 tthe $20 and the $15 US 10 day roaming add ons have unlimited talk and text. Stay safe.
07-18-2020 06:38 PM
@Ericsparrow56 wrote:So does that 20 dollar plan have UNLIMITED talk and text?:
Yes. When in the states. For 10 days. Unlimited talk and text. Limited days.
07-18-2020 06:35 PM
07-18-2020 06:07 PM
You would need to purchase a US roaming add-on.
U.S. Roaming Add-Ons with one service, or a combination. All U.S. Roaming Add-Ons will last 10 days. This 10-day period begins when you pay for the Add-On and ends 10 days later at 11:59PM ET.Below are some important things you should know about U.S. Roaming Add-Ons:
07-18-2020 05:56 PM - edited 07-18-2020 05:57 PM
@Ericsparrow56 yes, but roaming add-ons only last for 10 days
U.S. Talk, Text and 250 MB Data bundle: $20
U.S. Talk and Text Bundle: $15
U.S. Talk Only: $8
U.S. Text Only: $8
U.S. Data Only: 250MB for $10, 500MB for $15, 1GB for $20
07-18-2020 05:50 PM
@Ericsparrow56 Unfortunately, there are no unlimited addons for calling...
07-18-2020 05:50 PM - edited 07-18-2020 05:58 PM
No @Ericsparrow56 the $50 plan only allows you to call from within Canada to the US and there are only 10 day US roaming add ons available for calls from the US to Canada. If on android, you can use google hangout and google dialer combined over WiFi, or add the the TextNow app and use it over WiFi to make/ receive/ send calls and texts within Canada and to and from the US for free. Stay safe.
07-18-2020 05:49 PM - edited 07-18-2020 05:58 PM
Yes...there's 200 minutes add-on to US and Canada and also 400 minutes to several countries including to US. No add-on for unlimited calling though.
07-18-2020 05:45 PM
07-18-2020 05:43 PM - edited 07-18-2020 05:44 PM
@Ericsparrow56 hi, no with this plan you can only call us from canada. you will need to purchase a roaming add-on to use services in the US
