Us Roaming add on
Ken4
Does the US roaming add-on  talk&text include Hawaii?
8 REPLIES 8
@pkaraa wrote:
Yes, with AT&T and T-mobile partners, hawaii is pretty covered with compatible network with the US add-on.
Please note that this information was already provided several hours ago.  It's extremely important to realize that the quality of the messages posted counts, and that repetition is universally frowned upon in this Community.
pkaraa
darlicious
@Ken4
Here is some info about US roaming add ons that should help you.....
  1. While you have to have an active plan to purchase and use US roaming add ons the type of plan you have does not affect the roaming add ons features.
  2. US roaming add ons start the moment you confirm and submit your purchase in your self serve account and expire 240 hours later (10 days×24 hours).
  3. You can pre-load the funds needed to purchase the add ons in your self serve account so you only have to log in, select the US roaming add on and then confirm and submit your purchase.
  4. Wait til late as possible to purchase since they are immediately valid so on free wifi at the destination airport or stopping shortly before the border at mcd's or timmy's to buy the add on while on free wifi.
  5. If you are staying longer than 10 days you must wait a minimum of 24 hours to purchase the same US roaming add on or contact the moderators to add it before the waiting period ends.
  6. If you have two US roaming add ons with a talk feature that overlap the talk feature basically gets disabled. Avoid this....but you will have to get one removed by a moderator to get your calling feature back if this happens.
  7. After purchase reboot your phone and manually select either at&t or T-mobile to get better reception. Some areas have better coverage by either provider so when travelling around the US you will be better served by choosing the provider with better signal strength by locale.
  8. You will recieve incoming texts without any US roaming add ons. Adding the fongo app and textnow app for use on wifi are good to use for a back up plan or you could call forward your pm phone # to your fongo # before you leave Canada and purchase just the US data roaming add on. Fongo also works on mobile data (1 min=0.5mb/100 min=50mb) so you could still recieve incoming pm texts, recieve incoming pm calls to your fongo #/app, outgoing calls from your fongo number and outgoing  texts from textnow for free or small fee from fongo.
  9. All US roaming add ons have either unlimted text, talk or both. Only data has limits depending on your purchase 250mb/500mb/1gb. Once the data is consumed it will just stop you could then purchase different roaming add on, wait 24 hr to buy or contact the moderator to buy the same US roaming add on again. (* except talk as previously mentioned.)
Happy travels and Stay--Safe!
LeePublic
@Ken4
Have a safe trip there! 😁
Triguy
PM partners with AT&T and T-Mobile to provide you with fantastic coverage. Your U.S. coverage will include all 50 states, plus Puerto Rico and the U.S. Virgin Islands. For more details, check out our coverage map here.
HALIMACS
@Ken4
For pictures of coverage maps:
Coverage Maps
US Roaming Coverage
Hawaii Roaming Coverage
Alaska Roaming Coverage
Puerto Rico & Virgin Islands Roaming Coverage
@Ken4
yes all US,
sign in to Self-Serve, to review your account,
How To Purchase Add-Ons Using Your Self-Serve Account
To purchase Add-Ons using your Self-Serve account, follow these steps:
  1. Click on ‘Purchase Add- Ons’ on the Overview tab and scroll down to the Add-On calculator.
  2. Click the plus sign (+) to add and the minus sign (-) to remove selected Add-ons.
  3. When you’ve added all your desired Add-Ons, click ‘Buy Add-Ons’ or ‘Make a Payment’ below the calculator:
    • You will see ‘Make a Payment’ instead of ‘Buy Add-Ons’ if there are not enough funds in your account to make the purchase.
    • If you don’t have sufficient funds to purchase the Add-Ons, you will be asked to make a one-time payment equal to the price of the Add-On, less your current available funds. Click ‘Submit’, then ‘Go back’: now the button below the calculator will say ‘Buy Add-Ons’.
  4. Select ‘Confirm my purchase’, and you’re off to the races!
  5. after you Add-on you have to do Rebooting your phone
    what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Overview Of Add-Ons visit Here link.
Coverage (publicmobile.ca)
dabr
@Ken4   Yes it does, Hawaii is part of the US.
Edit:  BTW purchasing add-ons is a two step process, first add funds, then go back purchase the applicable add-on.  Also a reminder that the clock starts immediately on the roaming add-on as they're limited to 10 days.
