Cross border
02-27-2025
06:07 PM
02-27-2025
10:18 PM
computergeek541
I have a Canada, US, Mexico plan and am looking to travel in the spring,
Is there anything I need to do to ensure I don’t get roaming charges, or do I just keep using my phone as usual?
Service
02-28-2025 05:06 PM - edited 02-28-2025 05:06 PM
I agree, the whitelist was put together with members that had no problem.
What is the make and model of your phone so PM can update the whitelist?
02-28-2025 01:58 PM
When it comes to the whitelist ... Not necessarily... A lot of phones that are not on the list (like mine) just work perfectly. I would recommend going by the telus-tool to verify the status. There my phone shows up as supported. PMs list does not even list the brand I'm using.
Soooooo... Just as a suggestion...
02-27-2025 07:06 PM - edited 02-27-2025 07:14 PM
for use in Mx, you don't need a VoLTE certified phone as Mx still has their 3g networks intact unlike in USA where 3g has been retired. Make sure to enabled Data Roaming (just leave it on as there's no overages or extra charges with Public Mobile pre-paid service) To dial Canada from Mx, dial +1, area code, number. While in Mx, you might connect to AT&T, Telcel or Movistar....we have best service with AT&T.
ed
02-27-2025 06:10 PM
Just make sure Roaming is enable in your phone settings.
Also, if you are going to the USA. Enable VoLTE (voice over LTE) but your phone must be on the whitelist for your phone to work.
02-27-2025 06:10 PM
nothing much to do, you want get extra roaming charge
Just make sure you turn on roaming mobile data. Make sure your phone connects to AT&T or T-Mobile or Verizon if you are in US or AT&T or Telcel for Mexico. You might need to manually connect, and connect using network mode 4G
