Us Roaming Add-On
RobynW
What US networks does Public access when in the USA?  I can't seem to find that info on the website.
Thanks!
9 REPLIES 9
HI @DennyCrane
yours more recent, mine was in April
No, no AT&T. I was there is May and it was still only T-Mobile.
HI @Dunkman
So, is AT&T working again with roaming now?
last time I was there, I can only connect to TMobile, not AT&T
Fixed a couple typos! I meant to say AT&T used to work but now it's only T-Mobile.
@DennyCrane- ??? AT&T used to work. AT&T is still mentioned here. AT&T has not worked since last year. The only known confirmed roaming partner is T-Mobile. Standard, non-updated messaging around here. I guess we need a regular to check and test for AT&T now with all these changes and particularly volte. Or a game fellow customer who wouldn't mind fiddling with their phone.
hycm53
@hairbag1 wrote:
@Dunkman
I think you'll find that the 15 Day US Roaming add-on, no longer works on AT&T networks. That leaves only T-Mobile except for Alaska...there's no support for PM add-on there. For most other states, traveling PM'ers need to have a volte enabled phone AND have PM turn volte on...otherwise they'll find the talk portion of the add-on to be unreliable. W/O volte, it'll work in larger centers and diminish quickly as they move away from town. Text and data will be fine though.
But according PM website that PM partnered with AT&T and T-Mobile to provide you with fantastic coverage. I'm not sure PM partnered with AT&T come back.
https://www.publicmobile.ca/en/ab/get-help/articles/roaming-add-ons
@Dunkman
DennyCrane
AT&T silently got dropped as far as I'm aware. It's only T-Mobile now.
Dunkman
