Esim not working
Cct06
Won’t work with cell restarted cell and everything still having an issue.
2 REPLIES 2
HI @Cct06
activation completed?
maybe you need to submit ticket with agent, ask them to check your activation:
@Cct06
did you get to the eSIM installation step  Either the app will ask for your permission to do it for you automatically, or you will get a QR code to install yourself.  If you missed the step, there is a QR code in your Welcome email.  Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone
Once you installed the eSIM profile, (or If you got passed that step),  try to reboot your phone once.  i
If it still does not connect, click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetoosh connections, but you just need to add them back after)
if it still does not work, please open ticket with PM support
