Upgrading account.
TracyBird
I had the $50 account with 3Gand 10 g of data. Then I got an ad for an upgrade to a plan for $55 20 g of data and was supposed to get 4g. Everything was upgraded except the 4g. How do I get this fixed?
braydinn182
1) You need to make sure your mobile device supports 4G connectivity.
2) You need to be in a specific region that supports 4G connectivity.
3) In some cases, 4G connection m ay not be enabled on the device.
dabr
@TracyBird   Did you take the offer because of $20 off for 15 months on the $55/20GB plan?
Otherwise PM has $40/15GB or $45/20GB plans available for existing customers but you are advised to Change at Next Renewal option as PM doesn't prorate/refund for unused days left in your current cycle.
@TracyBird has it been 48 hours yet since the upgrade?
Also is your phone showing LTE? keep in mind, LTE=4G
you used some speed test app to test the speed?? what speed you got??
HALIMACS
@TracyBird
it may take up to 48 hours for the data to throttle up to 4G speed.
also, make sure that your network is set to LTE/4G
@TracyBird
Try again  incognito mode/private mode or simply try refreshing the page on the yellow circle while signed in to public mobile
Refresh page.                                ^^^
edit changing from 3G to 4G can take up to 48 hours before you notice a difference in speed
